Very beginner question ! but not in examples...
  • hello,
    i'd like to make a "simple" pano with hotspots.
    But when i click on a hotspot, i would like to have "layer" (or a div, or a frame or wathever it could be) displaying HTML informations, like a popup (not jumping to another area). For instance, if i click on a flower in a pano, i want to be able to display the name, the species, all kind of informations AND photos of it (some HTML).
    How would you do this ?
    is it something to add in the xml or in the js ?
    Thanks in advance.
  • hello,
    Thanks in advance.
    add
    <plugin name="editor"  url="%SWFPATH%/plugins/editor.swf" keep="true"  />
    then gen hotspot code automatically like image hotspot
    or polygonal hotspot
    write onclick like this
    onclick="action(showtextfield, flower);"
    add
    you can use following code for hotspot, instead of : XXXXXXXXXXXXXXXXXX you can write the text you want.
    <hotspot name="spot1" style="hotspot_ani_white"
    ath="239"
    atv="-3"
    zoom="false"
    onhover="showtext('XXXXXXXXXXXXXXXXXX-',hotspottextstyle);"
    onclick="set(view.maxpixelzoom,null);
    set(view.fovmin,30);
    looktohotspot(get(name),20);
    loadscene(scene_Warehouse_A, null, MERGE, BLEND(2));
    lookat(356, 0, 80);
    wait(LOAD);
    oninterrupt(break);
    wait(BLEND);
    lookto(170, 1, 100, smooth(45,45,40));
