some problem with Chrome mouse wheel zooming
    the reason is the Chrome-internal Flashplayer.
    But the newer swfkrpano.js scripts (at least 1.0.8.15) are already handling this Chrome problem - the newer scripts are manually capturing the mouse-wheel events inside the browser and then sending them via javascript to the krpano viewer.
    So I would recommend updating the swfkrpano.js.
  • something is wrong with that. My velden.js is 1.16.2
    "krpano Embedding Script
    krpano 1.16.2 (build 2013-04-12)"
    look here: http://www.tirol-images.com/panorama/kaern…hiff5/velden.js
    Igor Socha
    but a few lines later you are including the old swfkrpano.js (from 2012-01-16) and therewith overwriting the previous defined embedding functions:
    Remove that swfkrpano.js script including there completely.
  • Ahaa, mea culpa :)
    thanx
    Igor Socha
  • Hello Klaus!
    We downloaded krpanotools-1.16.8-mac64 - and the tour generated with "MAKE VTOUR (MULTIRES) droplet" has the same problem with the mouse wheel in Chrome. (And it seams that all 1.16 versions have, only 1.08.15 work). Is it only krpanotools for mac problem or it presents in Windows krpanotools also?
    We are not human beings having a spiritual experience. We are spiritual beings having a human experience.
    Pierre Teilhard de Chardin
