active non-active spot problem
  • I can't get my active spot visible on my floorplan. I have created a tour which has a floorplan in a scrollarea. All spots are visible (blue) but not the active spot (green) i want to have the active panorama on a greenspot.
    I have a tour which has a scalable floorplan where this works: http://77.248.102.192/360/tour_walibi/tour/index.html
    Here's my floorplan.xml code:
    In my pano.xml i use this:
    <scene name="woonkamer" title="woonkamer" thumburl="panos/woonkamer.tiles/thumb.jpg" heading="0.0" onstart="set(plugin[actievespot].x, get(plugin[spot1].x));set(plugin[actievespot].y, get(plugin[spot1].y));">
    Here's a preview of the tour right now: http://77.248.102.192/360/carbontree/tour/index.html
    Can someone help?
    The floorplan and pano.xml are attached.
  • I see your green active spot !!!
    Thats right i solved the problem halfway :)
    The 4 panorama's on the first floor are ok, but when you go up then the greenspots don't work.
    Here's the code i have now in the floorplan.xml
