Hello,
i want zoom in krpano <layer> in mobile(touch) device, How can i do this?
Thank You
Hello,
Thank You
here's an example:
https://krpano.com/examples/118/e…ch-zooming.html
It uses the onmousewheel event (which will be called also on touch devices on gesture zooms) and
touch devices the wheeldelta_touchscale variable for getting a scale value related to the zooming-gesture.
Wow! Very nice feature, Klaus! Many thanks!!
Thank You Klaus! It is Working
Can we set the minimum and maximum range of a zoom in <layer> because it the image in higher range?
I used this code, but got a strange problem. When the code is inside the scene, it works for the layer. But if I write this code outside the scenes, in order for it to work on all scenes, it does not work.
Here is an example:
<layer name="info_button_open" url="skin/info_hide_open.png" keep="true" align="righttop" align.mobile="righttop" width="20%" width.mobile="60%" height="prop"
onclick="set(layer[info].visible, false);
set(layer[info_button_close].visible, true);
set(visible, false);"
onover=" tween(layer[info_button_open].alpha, 1.0, 0.9)"
onout="tween(layer[info_button_open].alpha, 0.5, 0.9)"
x="0" x.mobile="0" scale="0.75" alpha="0.7" visible="false" crop="286|0|286|51" />
<layer name="info_button_close" url="skin/info_hide_open.png" keep="true" align="righttop" align.mobile="righttop" width="20%" width.mobile="60%" height="prop"
onclick="set(layer[info].visible, true);
set(layer[info_button_open].visible, true);
onover=" tween(layer[info_button_close].alpha, 1.0, 0.9)"
onout="tween(layer[info_button_close].alpha, 0.5, 0.9)"
x="0" x.mobile="0" scale="0.75" alpha="0.7" crop="0|0|286|51" />
<layer name="info" url="info.png" scale="0.6" align="center" edge="center" keep="true" visible="false"
onover="
set(iszoom, true);
set(startzoom, true);
copy(copy_mousefovchange, control.mousefovchange);
copy(copy_touchzoom, control.touchzoom);
set(control.mousefovchange, 0);
set(control.touchzoom, false);
onout="
set(iszoom, false);
copy(control.mousefovchange, copy_mousefovchange);
copy(control.touchzoom, copy_touchzoom);
ondown.touch="onover();"
onup.touch="onout();"
<!-- mouse wheel event for zooming -->
<events name="image_zoom_events" onmousewheel="image_onmousewheel();" />
<!-- the action for zooming either via the mouse wheel for via touch gestures -->
<action name="image_onmousewheel">
if(iszoom,
if(wheeldelta_touchscale GT 0,
<!-- touch zoom -->
if(startzoom,
set(startzoom,false);
copy(start_wheeldelta_touchscale, wheeldelta_touchscale);
copy(start_imagescale, layer[info].scale);
div(tmp, wheeldelta_touchscale, start_wheeldelta_touchscale);
mul(layer[info].scale, start_imagescale, tmp);
<!-- mouse wheel zoom -->
mul(sit,get(wheeldelta),0.05);
mul(sit,layer[info].scale);
add(layer[info].scale,sit);
add - keep="true" - to the <events name="image_zoom_events" ... /> element, then that event would be kept working when loading other scenes.
Thank you very much, Klaus !!!
It really helped me and gave me a reason to watch documents more often!
Hi all,
Based on Klaus' example for zooming an image
I tried to use the scrollarea.swf (krpano 1.19-pr12 ScrollArea Plugin (build 2017-08-04)).
Now the image is draggable but the onmousewheel event is not fired.
<krpano version="1.19.12" onstart="showlog(true);" >
<preview type="grid();" />
<layer name="zoom_canvas"
url="%SWFPATH%/plugins/scrollarea.swf" alturl="%SWFPATH%/plugins/scrollarea.js"
align="center" width="500" height="PROP" direction="all"
<layer name="image" url="img/Rychleby.jpg" scale="0.1" align="center" edge="center"
onover="
trace( %0,'(', %1 %2,') name=',name, ' ONOVER: control.mousefovchange=',control.mousefovchange, ' =', , ' tick=', timertick);
set(iszoom, true);
onout="
set(iszoom, false);
</layer>
<events name="image_zoom_events" onmousewheel="image_onmousewheel();" keep="true" />
<!-- the action for zooming either via the mouse wheel or via touch gestures -->
if(iszoom,
<!-- touch zoom -->
if(startzoom,
copy(start_imagescale, layer[image].scale);
mul(layer[image].scale, start_imagescale, tmp);
mul(sit,get(wheeldelta),0.01);
mul(sit,layer[image].scale);
add(layer[image].scale,sit);
Am I missing something?
Thank you,
Pavel
I found the post and it works now right. The mwheel attribute by default is true.
Sorry for bothering you.
Pavel
Hi all,
Please,
help me with the zooming action, which should keep focus when zooming under the mouse location.
I upgraded the Klaus' example for zooming an image from 1.18 to 1.19pr12.
The basic action calc_mouse_offset() works well when staying on starting mouse position. After moving the mouse there is an offset, which I can't find out.
(There are two actions in the code. The basic and my test attempt)
<action name="calc_mouse_offset">
<!-- to stay focused on the zoom in/out place of the image
%1 output
%2 [x,y] the x- or y- direction
calc(stage_half, stagewidth/2 );
if(%2 == 'y', calc(stage_half, stageheight/2 ););
calc(mouse_im%2, (stage_half - mouse.%2));
calc(%1, ((layer[image].scale - 1.0)*mouse_im%2) BOR 0);
dbg_swp(trace( %0,'(', %1 %2,')=',get(%1), ' mouse_im%2/mouse.%2=',mouse_im%2,'/',mouse.%2, ' IMAGE: ..scale=',layer[image].scale, ' ..stage_half=',stage_half, ' ..pixelwidth*=',layer[image].pixelwidth, ' ..pixel%2*=',layer[image].pixel%2, ' ..o%2=',layer[image].o%2, ' tick=', calc(timertick BOR 0)););
Hoping you direct me to the right logic.
Thank you to all.
Pavel
Klaus, please help!
I want to zoom in/out a draggable layer with a mwheel/swipe. Attached is my attempt but it works just in the middle of the image.
Would you be so kind giving me a clue what am I doing wrong?
The working test is based on your mwheel example.
Thank you,
Pavel
sorry, but I can't analyze or debug your code, but here attached the original mwheel-touch-zooming.xml extended with some code for dragging:
when mouse ondown also cause onup
add callwith action in asyncloop
<!-- some code for layer dragging -->
<action name="image_ondown_dragging">
copy(mstartx, mouse.x);
copy(mstarty, mouse.y);
copy(lstartx, x);
copy(lstarty, y);
asyncloop(pressed,
calc(x, lstartx + mouse.x - mstartx);
calc(y, lstarty + mouse.y - mstarty);
callwith(layer[image],onover);
Hi Klaus, tmhok, *...
Thank you for an attempt to help me though it's still not solved.
1) The attached example does zoom on the whole pano until the image is dragged or zoomed.
Not sure why the mouse wheel event over the whole pano is not working after the image is dragged/zoomed.
2) I separated the zooming offset from the dragging and mouse movement of the image.
The dragging and mouse movement makes change in the layer[image].ox while the image zooming sets the layer[image].x
The zoom is not working 100%. Apparently there is something wrong with me...
(My example is by now only for the x-direction).
Any help is appreciated.
Thank you,
Pavel
Magnification on the cursor
San,
Thank you for your input. My attached solution works aswell. But when applied in a container and scrollarea, it's not precise. I will check your code and will see. Please if possible let me know whether my code is running well on touch screen (iPad/iPhone/Android). I haven't tested it there.
Thank you again for your solution.
Pavel
San,
Pavel
I removed all the excess for ease of understanding of code Added
ondown.touch="onover();draglayer();"
now is dragged on the touch screen
now is dragged on the touch screen[quote='pur','index.php?page=Thread&postID=72957#post72957']Pavel
http://novosibpano.ru/VT/Zoom_and_drag_4/ if the image is big, when the zoom is activated, it do not reponsive for smatphone
Thank you,
Suso
Thank you,
Suso
