I have two sounds included, and they will start, when the pano is loaded.
In the navigation bar I have a button to stopallsounds. Is there a function like "playallsounds". Because it´s a tour and every tour has two different sounds and for the play all sounds button now I have to set the "playsound3D" a second time, and if I want to change the sound or some parameters I even have to change it twice.
So can I start all sounds in a scene with only one click automatically?
sound interface plugin (beta)
you could make a <action> where you start all sounds, and call this action...
or do you mean something different?best regards,
yes that must be the right way, as you give me the example in the other (german) thread, but it´s not working yet..
Regards Marc
Hi Klaus !
I can make a loop with "0"... But, would it be possible to define a timelapse between two repetitions of the same sound ?
In that way, if I've got differents sounds (like birdsongs, for exemple), I can define different timelapses, and, then, the sequence won't be always the same.
RegardsDavid
Is there two actions for loading sounds :
- preloadsounds (for loading all the sounds), and preloadsound, for loading a particular file ?
Thanks,
I would like that the volume grow when you zoom (little fov), and in the opposite, that the volume will be lower when the fov is higher !
Like in the real life !!
Is-it possible to do that ??? -
Is-it possible to do that ???that would be cool I am sure it is possible,if klaus has anything to do with it
Is-it possible to do that ???Hi,
currently it's not possible to control the volume of a sound interactively,
but it will soon, then changing the volume with the fov will be also possiblebest regards,
Super Cooool Mister K ! thank You !
... No holidays for Krpano ?? -
KlausSweet! This will make the feeling of immersion a lot better!
K
I have a project with hundreds of sounds spread throughout about 50 different scenes. They are all named differently.
I do not see a function or parameter for the soundinterface plugin itself that will mute it (or even provide a default volume?), thus preventing all sounds from being heard regardless of where and when they are called elsewhere in the tour?
I would like to make a global "mute" button of you will, that the user can turn on or off ALL sound.
Can this be done currently?
a global mute and global volume control is in work,
it will be available with the next release,best regards,
Is the global mute and volume working in the new release?
yes
what is the action to mute allsounds on/off in the last version???
stopallsounds()
stopallsounds() will work but that is old. They are talking global mute and volume control features added to soundinterface. there must be some new commands for them features but we do not know them yet.
there is a updated soundinterface plugin online,
please have a look at the first post here,
there is a link to the latest plugin version,now there are global volume, mute controls,
and pause/resume/pausetoggle actions,best regards,
I have a problem using sound interface in krpano.
I've created virtual tour made of 13 panoramas and I need to keep music played on background in every panorama. Problem is that music stops after using "loadpano" to load next panorama in tour.Is there any solution to play music without interruption on the background? Am I able to load next pano without stopping the music?
Thanks a lot for any feedback.
Kind Regards
Michal -
