Tuur: 100% sure you are not using the new version
your version
Content-Length: 10697 bytes
newest version:
Content-Length: 10701 bytes
I jut checked the one on the zip file and it is the newest version... so make sure you updated :)
your version
newest version:
mmm
sorry it's updated on this link now..
http://www.virtualtuur.com/Enkhuizen/tour.html
i deleted the swf and did fresh upload aswell... that's the only thing ? isn't it?? don't need to change something else??
seems to stay the same..
thumbMul is on 1.. with 0 it's better but it still slowly 'jumps' to the left when come close...
Thanx Shanti.. you deserve a BIG beer in the KRPano bar and cafe
tuur
Yet another revision!
Zitat26 March 2009 (Rev6)
Ok, ok, I know you probably hate me by now, but this time I think I finally killed that bug! it only took me about 6 revisions and about 20 hours or so :( but here it is!added debug option
<thumbDebug>0</thumbDebug>1 = on 0 = offchanged the way <thumbMul> works, if the thumbs stop to soon, or to late change this option, it acepts negative numbers too I found that if you show 5 thumbs at a time setting -3 works fine, but your milage will vary.
Well off too bed, 4 am here
that works fine.. but when i put the debug on 1 it shows the text of debug...mask ... etc..
but on 0 it's fine with mul on -5..
you gonna be completely useless when you come out the KRPano bar and cafe just for a day..
example debug on 1 http://www.virtualtuur.com/Naviduct/tour.html edit: sorry had to change back to 0
example debug on 0 http://www.virtualtuur.com/Enkhuizen/tour.html
Thanx shanti
sante
My problem with the plugin is already solved. When you pull the perfect bull and I explain that methods used to include it in the joomla.
Someone has set the IE plugin that sends an error 2025? The error is as follows.
Tuur: thats whats supposed to do, Debug 1 = Text that shows the position, It helped me fix the bug. keep it at 0 for the public :)
spasmos, sorry, I really didn't understand nothing :( what bull?
it would be easier if we could see a link
spasmos: Are you using another plugin that uses a loader?
Thanx shanti
i didn't know that... so it's done ... lucky you and us ofcourse..
Time for some beers!
Cheers
Good morning,
The example I have a http://ne-xe.com/_lab/pano/
As you can see, mozilla with no problem. It is with the view that the IE bug.
The code is krpano.xml this:
<krpano version="1.0.7" onstart="action(thumb01action);">
<display details="25" movequality="LOW" stillquality="HIGHSHARP" />
<plugin name="thumbnails" url="plugins/as3Thumbsforkrpano.swf?TheXML=panos/mnuimages/gallery1.xml" capture="false" keep="true" align="leftbottom" y="-20"/>
<action name="thumb01action">
loadpano(panos/recepcio/recepcio.xml,null,KEEPALL,BLEND(1));
lookat(37,3,90);
wait(blend);
<action name="thumb02action">
loadpano(panos/restaurant/jardi/jardi.xml,null,KEEPALL,BLEND(1));
lookat(-182,5,90);
wait(blend);
<action name="thumb03action">
loadpano(panos/restaurant/rest_1/rest_1.xml,null,KEEPALL,BLEND(1));
lookat(0,5,90);
wait(blend);
<action name="thumb04action">
loadpano(panos/restaurant/rest_2/rest_2.xml,null,KEEPALL,BLEND(1));
lookat(-58,5,90);
wait(blend);
<action name="thumb05action">
loadpano(panos/restaurant/rest_3/rest_3.xml,null,KEEPALL,BLEND(1));
lookat(50,5,90);
wait(blend);
and this is the gallery1.xml:
<?xml version="1.0" encoding="utf-8"?>
<images>
<thumboptions>
<thumbW>150</thumbW>
<thumbH>70</thumbH>
<ThumbOffset>0</ThumbOffset>
<InitialAlpha>0.2</InitialAlpha>
<ThumbPadding>10</ThumbPadding>
<ScrollSpeed>20</ScrollSpeed>
<ShownThumbs>5</ShownThumbs>
<font_type>Arial</font_type>
<font_size>20</font_size>
<font_alpha>1</font_alpha>
</thumboptions>
<pic>
<thumb>panos/thumbs/rest01.jpg</thumb>
<panoToLoadXml>thumb01action</panoToLoadXml>
<about>Kalamaki Beach 1</about>
</pic>
<pic>
<panoToLoadXml>thumb02action</panoToLoadXml>
<about>Pantokrator</about>
</pic>
<pic>
<panoToLoadXml>thumb03action</panoToLoadXml>
<about>Achilleion</about>
</pic>
<pic>
<panoToLoadXml>thumb04action</panoToLoadXml>
<about>Canal d' Amour</about>
</pic>
<pic>
<panoToLoadXml>thumb05action</panoToLoadXml>
<about>Pantokrator Abbey</about>
</pic>
</images>
Many thanks for your help and patience
can you elaborate on the bug?
I just tested your site on IE, FF, Opera and Safari, and it looks the same on all of them...
Hello,
is it possible to put gallery.xml inside krpano.xml?
Thank you,
Xavier
bazaar, no, sorry, it needs to be separated.
Really like the plugin, but I have been trying like crazy to lower the position of the thumbnails. They are always in the upper left side, the offset works, which shifted them to the right, but cannot lower them.
<krpano version="1.0.6">
<display fps="60" movequality="LOW" stillquality="HIGH" />
url="as3Thumbsforkrpano.swf?TheXML=gallery1.xml"
align="leftbottom"
keep="true"
I tried align="bottomleft" as in the readme.txt file. Tried align="left", align="right", align="rightbottom" even added y="200" but nothing changes.
Downloaded the most recent version, and used debug="1" but no errors.
Any suggestions?
you mean like in the bottom edge?
can I see an url?
I do not understand. When I went to my IE browser displays the error
message that I have given above and even if I load the plugin only
shows one picture and there should be 5 as can be seen in FF, safari,
opera...
Spasmos, I really don't see what you mean by this, what error?
can you post a screenshot? or at least explain what the error says?
Hi!
Is this plugin broken ?
I just downloaded it and tried; I included 3 thumbnails - but when it loads, it displays "1 of 3 Thumbnails loaded", and the About-text for that thumbnail is not properly aligned (it is waaaay to the right of the thumbnail). I figured I messed up the xml or something, but when I went to try the online example here on the site, I noticed that it suffers from the same problem - just one thumb nail and misaligned About-text. (and it displays "1 of 8 thumbnails loaded")
So I was wondering, whether it's a bugged version that is available for download, or if I am doing something wrong? (I tested on eifferent pc's and different browsers; same problem)
Thanks,
Hmmm... this seems to be an I.E.7 problem (both local and online, as well as winXP and Vista). Works fine on Google Chrome.
Runee, do you have an online link so that I can check it out?
BTW there seems to be a problem with Beta 7 and the plugin *cry*, I will try and fix it as soon as I hear from Klaus...
