Scrolling Thumbnails
  • Aksan: those errors are NOT with the thumbnail plugin, the thumbnail works perfectly here on chrome
    ARNING: unknown action command: plugin[maps].pantospot
    INFO: CameraControls v1.0 Author: Andrei Stanescu
    ERROR: download of "http://www.ankamall.com.tr/ankamall3d/compass_system/panoramıiweblogo.png" failed
    WARNING: unknown action command: smooth
    but those errors are not with the thumbs plugin
  • This was from IE7
    INFO: krpano 1.0.8 beta 8 (build 2009-06-15)
    INFO: Flashplayer WIN 10,0,32,18 ActiveX
    INFO: registered to: ulas aksan
    If you go to the link,
    you will notice the error page shows this as a filename instead.
    I wonder if the lettering is your issue?
  • Hello to all,
    I spent the last days working on implementing the scrolling thumbnails. But, whatever I do, it is not working. I can only see my panorama without thumbs.
    I work with Mac and the browser is Safari.
    I tried to make sure that the structure is the same as described.
    When I open my panorama in Safari I get the following error message: file:///Users/wilfried/Pictures/Panoramen/Thumbnails/undefined.
    Everything else including file:///Users/wilfried/Pictures/Panoramen/Thumbnails/as3Thumbsforkrpano.swf?TheXML=1.xml was found.
    I really don't know what I do wrong and I would appreciate any help in solving my problem.
    Thank you so much!!!!! Wilfried
    This is my complete xml
    tour.xml
    <krpano version="1.0.8" onstart="action(Museum1);">
    <plugin name="thumbnails"
    url="as3Thumbsforkrpano.swf?TheXML=1.xml"
    align="leftbottom"
    keep="true"
    <memory maxmem="350" />
    <network downloadqueues="" decodequeues="" />
    <events onenterfullscreen=""
    onexitfullscreen=""
    <progress showload="bar(lefttop,8%,6,3,3,solid, 0x000000,0xFFCC00,0xFFCC00)" showwait="none" />
    <display fps="60"
    details="32"
    tessmode="0"
    movequality="LOW"
    stillquality="HIGH"
    <contextmenu fullscreen="true">
    </contextmenu>
    <autorotate enabled ="false"
    waittime="3.0"
    accel ="1"
    speed ="2.5"
    horizon ="0"
    tofov ="NaN"
    <textstyle name="default" font="Times" fontsize="12" bold="true" italic="false"
    textcolor="0" background="true" backgroundcolor="16777215" border="true" bordercolor="0"
    alpha="1" blendmode="normal" effect=""
    origin="cursor" edge="bottom" textalign="none" xoffset="0" yoffset="-3" showtime="0.1" noclip="true"
    <!-- showtext styles -->
    <textstyle name="buttonstyle"
    font="Arial" fontsize="10"
    border="false" background="false"
    textcolor="0xFFFFFF"
    effect="glow(0x000000,0.7,4,2);dropshadow(2,45,0x000000,3,1);"
    <!-- plugins -->
    <!-- button over effect -->
    <action name="overeffect">
    set(blendmode,add);
    tween(plugin[in].scale,1);
    tween(plugin[out].scale,1);
    tween(plugin[left].scale,1);
    tween(plugin[right].scale,1);
    tween(plugin[up].scale,1);
    tween(plugin[down].scale,1);
    tween(plugin[home].scale,1);
    tween(plugin[openfs].scale,1);
    tween(plugin[closefs].scale,1);
    tween(plugin[in].x,-160);
    tween(plugin[out].x,-120);
    tween(plugin[left].x,-80);
    tween(plugin[right].x,-40);
    tween(plugin[up].x,0);
    tween(plugin[down].x,40);
    tween(plugin[home].x,80);
    tween(plugin[openfs].x,120);
    tween(plugin[closefs].x,120);
    <!-- button out effect -->
    <action name="outeffect">
    set(blendmode,screen);
    tween(plugin[in].scale,0.5);
    tween(plugin[out].scale,0.5);
    tween(plugin[left].scale,0.5);
    tween(plugin[right].scale,0.5);
    tween(plugin[up].scale,0.5);
    tween(plugin[down].scale,0.5);
    tween(plugin[home].scale,0.5);
    tween(plugin[openfs].scale,0.5);
    tween(plugin[closefs].scale,0.5);
    tween(plugin[in].x,-80);
    tween(plugin[out].x,-60);
    tween(plugin[left].x,-40);
    tween(plugin[right].x,-20);
    tween(plugin[down].x,20);
    tween(plugin[home].x,40);
    tween(plugin[openfs].x,60);
    tween(plugin[closefs].x,60);
    <!-- direction/zoom buttons -->
    <plugin name="in" url="btn_plus.jpg" align="bottom" edge="bottom" y="20" x="-80" scale="0.5" blendmode="screen" ondown="set(movevectorz,-1);" onup="set(movevectorz,0);" onover="action(overeffect);" onout="action(outeffect);" />
    <plugin name="out" url="btn_minus.jpg" align="bottom" edge="bottom" y="20" x="-60" scale="0.5" blendmode="screen" ondown="set(movevectorz,+1);" onup="set(movevectorz,0);" onover="action(overeffect);" onout="action(outeffect);" />
    <plugin name="left" url="btn_left.jpg" align="bottom" edge="bottom" y="20" x="-40" scale="0.5" blendmode="screen" ondown="set(movevectorx,-1);" onup="set(movevectorx,0);" onover="action(overeffect);" onout="action(outeffect);" />
    <plugin name="right" url="btn_right.jpg" align="bottom" edge="bottom" y="20" x="-20" scale="0.5" scale="0.5" blendmode="screen" ondown="set(movevectorx,+1);" onup="set(movevectorx,0);" onover="action(overeffect);" onout="action(outeffect);" />
    <plugin name="up" url="btn_up.jpg" align="bottom" edge="bottom" y="20" x="-0" scale="0.5" blendmode="screen" ondown="set(movevectory,-1);" onup="set(movevectory,0);" onover="action(overeffect);" onout="action(outeffect);" />
    <plugin name="down" url="btn_down.jpg" align="bottom" edge="bottom" y="20" x="+20" scale="0.5" blendmode="screen" ondown="set(movevectory,+1);" onup="set(movevectory,0);" onover="action(overeffect);" onout="action(outeffect);" />
    <!-- hotspot/home/info/fullscreen buttons -->
    <plugin name="home" url="btn_home.jpg" align="bottom" edge="bottom" y="20" x="+40" scale="0.5" blendmode="screen" onhover="showtext(Move to Home, buttonstyle);" onover="action(overeffect);" onout="action(outeffect);" onclick="lookto(0.0,0.0,97);" />
    <plugin name="openfs" url="btn_openfs.jpg" visible="true" align="bottom" edge="bottom" y="20" x="+60" scale="0.5" blendmode="screen" onhover="showtext(Enter Fullscreen, buttonstyle);" onover="action(overeffect);" onout="action(outeffect);" onclick="set(fullscreen,true);" />
    <plugin name="closefs" url="btn_closefs.jpg" visible="false" align="bottom" edge="bottom" y="20" x="+60" scale="0.5" blendmode="screen" onhover="showtext(Exit Fullscreen, buttonstyle);" onover="action(overeffect);" onout="action(outeffect);" onclick="set(fullscreen,false);" />
    <!-- fullscreen events -->
    <events onenterfullscreen="set(plugin[openfs].visible,false); set(plugin[closefs].visible,true);"
    onexitfullscreen="set(plugin[openfs].visible,true); set(plugin[closefs].visible,false);"
    <!-- actions -->
    <action name="Museum1">
    loadpano(1.xml,null,KEEPALL,BLEND(2));
    lookat(5,0,90);
    wait(blend);
    <action name="Museum2">
    loadpano(2.xml,null,KEEPALL,BLEND(2));
    lookat(0,0,90);
    wait(blend);
    <action name="Museum3">
    loadpano(3.xml,null,KEEPALL,BLEND(2));
    lookat(0,0,90);
    wait(blend);
    <action name="Museum4">
    loadpano(4.xml,null,KEEPALL,BLEND(2));
    lookat(0,0,90);
    wait(blend);
    <action name="Museum5">
    loadpano(5.xml,null,KEEPALL,BLEND(2));
    lookat(0,0,90);
    wait(blend);
    1.xml
    <krpano version="1.0.8" encoding="utf-8" >
    <images>
    <thumboptions>
    <thumbW>140</thumbW>
    <thumbH>70</thumbH>
    <ThumbOffset>0</ThumbOffset>
    <InitialAlpha>0.2</InitialAlpha>
    <ThumbPadding>10</ThumbPadding>
    <ScrollSpeed>20</ScrollSpeed>
    <ShownThumbs>5</ShownThumbs>
    <font_type>Arial</font_type>
    <font_size>20</font_size>
    <font_alpha>1</font_alpha>
    </thumboptions>
    <pic>
    <thumb>thumbs/01.jpg</thumb>
    <panoToLoadXml>Museum1</panoToLoadXml>
    <about>Panorama 1</about>
    </pic>
    <pic>
    <thumb>thumbs/02.jpg</thumb>
    <panoToLoadXml>Museum2</panoToLoadXml>
    <about>Panorama 2</about>
    </pic>
    <pic>
    <thumb>thumbs/03.jpg</thumb>
    <panoToLoadXml>Museum3</panoToLoadXml>
    <about>Panorama 3</about>
    </pic>
    <pic>
    <thumb>thumbs/04.jpg</thumb>
    <panoToLoadXml>Museum4</panoToLoadXml>
    <about>Panorama 4</about>
    </pic>
    <pic>
    <thumb>thumbs/05.jpg</thumb>
    <panoToLoadXml>Museum5</panoToLoadXml>
    <about>Panorama 5</about>
    </pic>
    </images>
    <!-- the preview and pano image -->
    <preview type="CUBESTRIP" url="cube_1.tiles/preview.jpg" />
    <image type="CUBE" multires="true" tilesize="524">
    <level tiledimagewidth="3144" tiledimageheight="3144">
    <left url="cube_1.tiles/l3_l_%0v_%0h.jpg" />
    <front url="cube_1.tiles/l3_f_%0v_%0h.jpg" />
    <right url="cube_1.tiles/l3_r_%0v_%0h.jpg" />
    <back url="cube_1.tiles/l3_b_%0v_%0h.jpg" />
    <up url="cube_1.tiles/l3_u_%0v_%0h.jpg" />
    <down url="cube_1.tiles/l3_d_%0v_%0h.jpg" />
    <level tiledimagewidth="1572" tiledimageheight="1572">
    <left url="cube_1.tiles/l2_l_%0v_%0h.jpg" />
    <front url="cube_1.tiles/l2_f_%0v_%0h.jpg" />
    <right url="cube_1.tiles/l2_r_%0v_%0h.jpg" />
    <back url="cube_1.tiles/l2_b_%0v_%0h.jpg" />
    <up url="cube_1.tiles/l2_u_%0v_%0h.jpg" />
    <down url="cube_1.tiles/l2_d_%0v_%0h.jpg" />
    <level tiledimagewidth="786" tiledimageheight="786">
    <left url="cube_1.tiles/l1_l_%0v_%0h.jpg" />
    <front url="cube_1.tiles/l1_f_%0v_%0h.jpg" />
    <right url="cube_1.tiles/l1_r_%0v_%0h.jpg" />
    <back url="cube_1.tiles/l1_b_%0v_%0h.jpg" />
    <up url="cube_1.tiles/l1_u_%0v_%0h.jpg" />
    <down url="cube_1.tiles/l1_d_%0v_%0h.jpg" />
  • Hi Wilfried,
    Path problem maybe?
    Try to use %SWFPATH% placeholder in your url...
    %SWFPATH%
    means path of the krpano.swf file. Asuming that the path (relative to krpano.swf) to the as3Thumbsforkrpano.swf is Thumbnails/as3Thumbsforkrpano.swf, the url would be: %SWFPATH%/Thumbnails/as3Thumbsforkrpano.swf
       	url="%SWFPATH%/Thumbnails/as3Thumbsforkrpano.swf?TheXML=1.xml"
       	align="leftbottom"
       	keep="true"
    SAlut.
  • Hi Wilfried,
    OK, first time I use this plugin... Sure I will use it in future (and perhaps send some beers to Shanti *wink* )...
    So, you have all the needed files in the same folder, then your plugin code was correct...
             align="leftbottom"
             keep="true"
    I think the problem is that the plugin loads correctly but you do not see the thumbs... I think this is because your 1.xml is mal formed.... try erasing the <krpano version="1.0.8" encoding="utf-8" > line .
    Hope this solve the problem.
    SAlut.
  • Hello Michel,
    Thanks but I get the same error message.
    I changed the first line in the 1.xml - according to what you told me to do. I erased the first line completely, (<krpano version="1.0.8" encoding="utf-8" >) and I got the same error message parser error.
    How do you think the first line should look like? I am clueless.....
    Thank you, Wilfried *confused*
  • Hi Michel,
    I downloaded the latest verstion of rev7 but I had it already. Perhaps you are correct that I have to change the first line but I have no idea to what.
    I don't have a link to the not working panorama. It is not online.
    Thank you very much for all your help!!!! Perhaps somebody else has a different idea.
    Sincerely, Wilfried
  • Does anyone know a way to use the scrolling thumbnails plugin so it can be used outside the krpano viewer, instead of on top of the pano - html/javascript code that will allow this plugin to interface with krpano?
    BobC; this plugin is only for krpano, but the JS code is surely doable with any pre-existing scroller, even those nice Jquery ones, a JS interface is provided with the krpano package, just check the syntax on how to load a pano from JS.
    I have been using krpano and its plugin since a year. All the plugins work as expected. I downloaded the thumbnails plugin yesterday but I am not able to get it work. It does't give me any error and I guess the problem might be related to the paths. I am using krpano 1.0.8 beta and as3Thumbsforkrpano (rev 7).
    You may check my krpano tour here:
    http://panoview.co.nz/property_tour.…pe=3&nCodItem=0
    krpano XML:
    http://panoview.co.nz/inc/property_t…dClProp=7-358-1
    Thumbnails XML:
    Here is the directory structure:
    krpano.swf -http://panoview.co.nz/players/krpano/
    as3Thumbsforkrpano.swf - http://panoview.co.nz/players/krpano/
    PHP Script that generates Xml Files: http://panoview.co.nz/inc/property_tours/
    I would really appreciate if anyone could help me trace the problem.
    Best Regards
    Praveen
  • Hi Praveen,
    After some scratching the head *confused* *wink* ...
    The first problem was a wrong variable name... as3Thumbsforkrpano.swf?TheXMl= ... must be ?TheXML=
    The second problem was the path to the xml...
     	    	url="./inc/property_tours/%SWFPATH%as3Thumbsforkrpano.swf?TheXML=./inc/property_tours/getThumbnailXml.php"
    SAlut.
  • Hi Michael,
    Thank you very much for throwing light on this. This was helpful and thumbnails are now visible. Could you help me in one more thing:
    1. Thumbnails are not scrolling. They remain stationary.
    2. I would like to place them about 15px above the navigation button at the bottom. What change do i need to make?
    Best Regards
    Praveen
    Hi Praveen,
    SAlut.
  • Hi Praveen,
    After more scratching the head *confused* *wink* ...
    Your thumbnails plugin:
    	x="" y="75"
    	align="leftbottom"
    	keep="true"
    Your thumbnails xml:
    The <ThumbOffsetY> is a little strange *confused* (for me *wink* )...
    Taking the leftbottom as reference and <thumbH> attribute value to 70, if I want the thumbs appearing at 0,0 leftbottom, It seems that the <ThumbOffsetY> attribute must have a value of 230...
    If <thumbH> value to 50, then <ThumbOffsetY> must have a value of 250...
    I conclude that <ThumbOffsetY> must have a value of (300 - <thumbH> value)...
    Perhaps Shanti would explain better this *smile* ...
    SAlut.
  • Hello again,
    As described in posting 184 my thumbnails are still not visible.
    My understanding is that I have to put <?xml version="1.0" encoding="utf-8"?>
    in 1.xml. Is this correct?
    If I type this in my text editor, it is displayed in red as an error and I also get the following error message 1.xml-XML parser error: #2070
    when I open the pano with the browser.
    I would really happy if anyone could help me.
    Best Regards
    Wilfried
