Please contact me mail @ talas-is.ru
and describe what you wnat
I will try to help you
Regards
Andrey
Regards
Andrey
Hi Andrey,
what´s about MAC-droplet? still working on it?
Regards,
Marc
Thanks for the quick reply, Andrey. I'll be touch soon.
Stuart.
Hello!
MAC droplet ready at last
copy this to krpano tool folder
enjoy
Andrey
PS - please, somebody try it, and let me know it's OK or not..... many thanks in advance
Hi Andrey,
I´m having problems with the MAC droplet. After creation, the [SCENES] in tour.xml stays empty...
regards,
marc
Hi!
Hm... strange..
Are you copied default_black skin to your krpano tools folder too?
Please, describe more detailed, and if you can, contact me mail @ atlas-is.ru
Many thanks for report
Andrey
Andrey,
I'm very interested in your krpanoGUI project. Any updates on when this may be ready?
Thanks!
Hi!I think you will see "ugly beta" before february ends.
Regards
Andrey
Hi Andrey,
Is it possible to include a video/audio in a tour using Framework? will it worked on iDevices?
I am thinking like the flyout for photos, but instead of showing photos, it shows a video.
And for the audio: when a hotspot clicked, the audio will automatically played (no need to have fly out like photos)
Thank you :)
Hi!You can add any tag you want.
In main tour.xml or layout.xml
or even made new xml and include it in main tour.xml
So, if you want add video just do it as always.
If you want to show it in window then take a look at example (Show image button)
this action - _window_new(win1,580,380,someimage);
create new window with name win1 and size 580x380
someimage - it's plugin name for show as content of window
for example: you add some plugin with videoplayer and give name my_video and size 400x300
you want to show it in a window
then call action _window_new(win_video,400,300,my_video);
visible sets to true automaticaly
Hope it help
Andrey
Will the new Krpano GUI have a map builder?
Hi!
I think yes
Andrey
In main tour.xml or layout.xml or even made new xml and include it in main tour.xml. So, if you want add video just do it as always. If you want to show it in window then take a look at example (Show image button) this action - _window_new(win1,580,380,someimage); create new window with name win1 and size 580x380
for example: you add some plugin with videoplayer and give name my_video and size 400x300, you want to show it in a window, then call action _window_new(win_video,400,300,my_video);, visible sets to true automaticaly
Hope it help
Andrey
Thank you for the tips Andrey, will have to digest it for a while since i've never tried to add video to a pano before..:D
Meanwhile, I've managed to compile 17 panos including hotspots using Framework:
http://bit.ly/AsianAfricanConference (do mind the image quality since i still use resized & unedited image for coding purposes)
I still have difficulties finding which code to tweak for the following weird behavior:
1. Fullscreen button: works fine on Firefox 10.0, doesn't work on Chrome 17.0.963.46 & Safari 5.1.3. Maybe anyone could take a look at the tour and give me feedback if it is working/not...Thank you ;)
Previously (couple of days back) Andrey has told me it was working fine at his desktop, but mine is still not working.
2. Title Bar: I can't get it aligned center for desktop & iPad; and if the title is too long, it will make a second line, and aligned left. Click on the 2nd and 10th-17th pano to see example. As for the iPhone works fine for me.
I use this code at layout.xml for the title bar
<plugin name="_scene_title" url="%FIRSTXML%/plugins/textfield.swf" keep="true"
parent="_interface2"
edge="center" align="center" x="0" y="-1"
enabled="false" selectable="false" background="false" borderwidth="0" autosize="left"
effect="glow(#000000,1,3,1.5)"
zorder="0"
<plugin name="_interface2" url="skin.png" keep="true" alpha="0.5"
edge="lefttop" align="lefttop" x="0" y="-1"
crop="0|274|500|26"
width="100%" height="26"
dragX="false" dragY="false"
zorder="1000"
Any suggestion would be much appreciated
UPDATE
For point number 2 >> I think i solved this. It is now centered and not creating a second line if the title is quite long. The solution is i add onclick (line 14) and refer the width value at line 3. In this case i change the value to 600.
<settings name="interface"
_tour_title="Tour title"
title_width="600"
first_scene=""
help_image_url="%FIRSTXML%/skin/default_black/help.png"
title_css="color:#ffffff; font-family:Arial; font-size:15px; text-align:center; margin:0px; text-shadow:#000000 0px 1px 2px"
_scene_title_css="color:#ffffff; font-family:Arial; font-size:15px; text-align:center; margin:0px; text-shadow:#000000 0px 1px 2px, #000000 0px 1px 2px"
onloaded="copy(width,settings[interface].title_width);"
zorder="0"
Hello again :D
This time I found this behavior:
This behavior will repeat itself when you reload the panorama again.
Any suggestion how to eliminate this behavior?
UPDATE
I think I found a solution (maybe..hehehe).
I set the value of x in the code to a large negative value,
<plugin name="text" url="%CURRENTXML%/plugins/textfield.swf" keep="true"
edge="lefttop" align="lefttop" x="-1000000000" y="5"
width="465" selectable="false" background="false" autosize="center" html="data:text" css="data:css" fixlimits="true"
Hi Andrey,
in your settings there is a "first_scene" parameter which i had to turn out to let the SWFAddress plugin to start with the scene which has been taken from URL.
In the "layout.xml" line 204 i made this:
<!--if(settings[interface].first_scene == '', copy(settings[interface].first_scene,scene[0].name); );-->
_button_switched(_thumbs_open,true);
<!--_gotoscene(get(settings[interface].first_scene));-->
it works so far but i am not sure it is the right way to solve this problem. The oher thing is that the frame for current scene thumb coldn't be assigned at the begining. It hangs between the thumbs until i click on the thumb to go to the next scene.
Your code is not comented so it takes time to understand how did you make it.
Could you give me a hint how to fix it in a proper way??
greetz
Mil
i've solved this without changing "layout.xml"
in "swfaddress.xml" i added
<action name="activatepano">
if (%2 == scene, set(settings[interface].first_scene,%1);loadscene(%1,null,KEEPBASE,BLEND(1)));
if (%2 == xml, loadpano(%SWFPATH%/%1,null,KEEPBASE,BLEND(1)));
wait(blend);
greetz
Mil
Hello!
small bug fixed:
loading... text not disapear if click "?" again
for fix it
find this row in core.xml
if(%3 != null, set(plugin[%1].url,%3); );
and replace with
if(%3 != null, if(%3 != plugin[%1].url, set(plugin[%1].url,%3); ); );
Regards
Andrey
Whats the status of KPGUI ?
I am interested to buy it.
Hi!
Almost done.
Currently I'm working on pano image add wizard. (1-2 week left, maybe faster)But if you can make it manualy i can sell KPGui for you with discount, as for first customer.
Contact me : mail @ atlas-is.ru
Regards
Andrey
BTW - you can try it, demo version is already available
I will share the link at monday.
dont get you manually ?
