• Here's the link:
    http://www.marcolanciani.com/redbaronclub
    Following the code of a pano:
    Following the code of the global.xml:
  • i don't see the code to load the pictures in the global.xml...and also no includes
    did you put that in the swf ?
    don't!
    cheers
    Tuur *thumbsup*
  • set in safari develop to user iphone..
    or use the iphone simulator
    alot of problems...
    have to sleep now
    01:10
  • I tried to view your images on the iphone and desktop and they seem to be encrypted. I don't think the iphone.js can deal with the encrypted image files.
    The image “http://www.marcolanciani.com/redbaronclub/3401.tiles/preview.jpg” cannot be displayed because it contains errors.
    Yes, images in the tile folder are encripted. Do you think this is the only problem?
  • Zitat
    you can only encrypt xml for the mobile devices
    edit ok i wait
    tuur
  • I haven't used encryption since I started using iphone .js. I am not sure what can and cannot be encrypted. I believe only xml can but as you are testing, it would be best to get it working without any encryption and then test from there as to what can be encrypted.
  • just encrypt xml if you want as a last step.. nobody can find your pictures when then.. you put them on an other map with name: jaredjahasnicelongblondhair or what ever
    *thumbsup*
