Tuur u r so quick reply... :)
air compass
Quick and cheap
i think.. can we limit or hide or fade air compass in ath.. so when view angle up (horizon & above) air compass will disapear...
Hello
'airhotspot' was applied and 'aircompass' was made.
http://www.dowjow.com/panorama/2012p…pot_e/tour.html
I wanted to make this from the beginning.
The problem still remains.
However, I am very glad.
Thank you for people which gave advice.yasushi kumon
Hi Yusashi, do you have this version of the aircompass for sale yet?
It looks great for my needs.
I look forward to hearing from you.
Hi virtual pete,
It is a great plugin by Yasushi Kumon!
you can get it here:
http://www.dowjow.com/panorama/2012/03/aircompass.php
hope it helps
Thanks Tuur, but I dont think when you buy yu get the code to be able to make it like this with the clickable hotspots
I have asked Yasushi if it is possible for the code if I buy it.
Can plz anyone guide how to apply airhotspot replaceing default with aircompass ?
Hi!
If replace
toCodeadd(hset,get(header),90); sub(vang,90,get(view.vlookat)); set(hotspot[level].rz,calc:-1*(hang));
then can not flip the image
Then I thought, what if instead of the image to insert html page via iframe. Get the next http://panosphera.ru/gallery/map/
I think possible to add hotspotsp.s. sorry my english)
I mistook.
This is the completion version.
Please see.Thank you I receive the code
Always wanted to put the aircompass somewhere else in the screen..not in the center.
https://www.virtualtuur.com/krpano/120/examples/aircompass/1/
with layer type krpano
I wanted to make this, but it didn't work and I gave up.
It's so wonderful ! -
