Two men in a boat...
Very Nice...
Like the quality of the photo!!
I have to learn some more photoshop..
Cheers
...Any particular reason you took a portion of the roof off?
There is no portion of the roof off. This a very very old boat as you can see, one of the latest boats of this type which was built at the beginning of the last century. I can't find the documentation about it, but I'll try to find it soon. The owner of this boat lives near Geneva in Switzerland (sitting on the chair).
The man standing with lensflares in the eyes is my man.
It looks like an "salon" boat .. there are some in Amsterdam .. Very nice old boats..
http://www.bootnodig.nl/rent_a_boat_salon_boat.html
http://www.classiccanalcharters.com/eng/schipjeanschmitz.htm
http://www.classicboattours.nl/index.php
am i right ? MA?
Cheers
Tuur -
hey, MA!
you do great stuff!
the only thing i found is the following (because im on a slow line):your panos start rotating before they are loaded, so i see only black...
you should integrate this: -
I see it now : )
I didn't realize that on either side of the center, the roof is actually canvas and can be folded back over to open it up... and I just jumped to an incorrect conclusion that it was digitally removed... which if I had looked at the photo gallery I would have seen how it worked originally.
Hi all,
If you see the VR again, you can hear the sea birds, you will get some information (not ended yet) and you will see some pictures of the boat. I think the whole is rather heavy, but it worth waiting 2 or 3 seconds, is not it ?
hey, MA!
you do great stuff!
I tried your code, but it doesn't work. I think there's something I did not understand. Do you mean that exactly :<krpano version="1.0.7" onstart="action(start);" "set(autorotate.enabled,false);" basedir="%FIRSTXML%" actionintervalbase="timer" logkey="true">
<events onenterfullscreen=""
onexitfullscreen=""
onloadcomplete="set(autorotate.enabled,true);"
hello, ma!
i just have exactly this code in the first xml... as beginning...
and then this:
you can see it here: (site is still under construction)
Vielen Dank ! Schöne beispiele has du auch... I'll try again very soon.
"Ma"
danke ;)
Ma,
what is the info box?
is it flash? When I close Info, the whole pano loads from benigning. If I close Photos, it works OK.Is it posiblle to close Info without reloading the whole pano?
Martin
Ma,
is it flash? When I close Info, the whole pano loads from benigning. If I close Photos, it works OK.Is it possible to close Info without reloading the whole pano?
Martin
Very good question. The info box is a home-made-flash. I tried to find solutions not to reload the whole pano, but unfortunately could not find the solution. Why ? Because the event "click" is already used by this flash (when you click, the following page of the little leaflet appears).So, I take the opportunity to ask Klaus :
Can we use "double click" and if it is possible, how should we write it ?
I only saw this type of writing in xml files :
onclick=""
I had a look directly to Adobe Flash, and saw onDbleclick="" but it doesnot work. It would have been the solution for me.
Thank you for your reply Klaus if you read this post.
sorry, double clicking is not possible, it is disabled the moment because there were some problems with it,
would it be possible to remove the "Hide button" from the flash book?
then you could add a krpano <plugin> image instead of it - order it over the book with a higher "zorder" value
and assign to the onclick event of this image an action that hides the book,
e.g.I hope this helps a little bit
btw - great pano!best regards,
I am very curious.
Go for it, Ma. -
KlausOk, thankyou, as soon as I have some free time I try and let you know about the results.
...would it be possible to remove the "Hide button" from the flash book?
and assign to the onclick event of this image an action that hides the book...KlausHi Klaus,
I was inspired by what you said above, and I find a solution to keep the click event for the book only. In fact, the book disappear just by the "out event" now and it's ok for me. Here's the link again :
http://www.visites-interactives.eu/fr/visite-lakshme/lakshme.html
Ma
Ma
Hi Ma,
could you share the XML?
Martin -
Hi Ma,
Martin
The most interesting part of xml is here :<plugin name="navimap"
url="infos.swf"
keep="false"
visible="false" enabled="true" handcursor="true" capture="true" children="true"
zorder="1"
alpha="0.00" blendmode="normal"
smoothing="true"
origin="center" edge=""
x="0" y="0"
width="" height=""
scale="1"
onloaded=""
onover=""
onhover=""
onout="set(plugin[navimap].visible, false);
set(plugin[navimap_show].alpha,0);
set(plugin[navimap_show].visible,true);
timerset(0.3,0,plugin[navimap_show].alpha,0,1,linear,,false);"
ondown=""
onup=""
onclick="set(plugin[navimap_show].alpha,0);
set(plugin[navimap_show].visible,false);
