Hello,
I'm using for the first time soundinterface.swf and it works fine.
I have buttons which play mp3 files and other buttons which stop playing mp3 files.
I was just wondering if it is possible to add a fade effect when i stop playing a sound/loop ?
Maybe not ? I guess the "stop playing sound action" close the stream immediatly as in as3 :
It's the same with "close method" for video, it stops the stream without fade effect.
Do you know if it is possible to make a fade effect, and then close the stream ?
ps : Sorry, maybe this topic should be in plugins/souninterface topic ... But it is also related to AS3
