this is the discussion thread for the Camera Controls Plugin from Andrei Stanescu
Andrei Stanescu thank's a lot
Very nice ..
Thanx
I also like the fullscreen toggle... Klaus...
Can you put that here as an plugin to ??
Thanx a lot
the fullscreen toggle is very simple
it's just a tween() to change the scale of the plugin on an enter/exit fullscreen event:
i mean the thing on the right side on your example on the site
Thanx
this works in the same way:
scale and rotate is changed on an fullscreen event
here you find the full xml code of this example:
https://krpano.com/plugins/userpl…ols/example.xml
thanx!!
I also like the fullscreen triangle and the scaling. I have added it to a few of our panos. But how in gods green earth do you get the triangle to work in the upper right hand corner instead. I cannot get it to rotate correctly from the top right hand corner. it is driving me absolutly nuts. I have flipped the canvas in photoshop and rotated the opbject every which way till sunday and it will not rotate from the top right then fall inside the pano it always rotates off screen.
and how come when it is in the bottomright and all ox,oy.x.y and all set to 55 is stays in the exact corner and just changing the alignment to righttop is does not sit anywhere near the corner? this offset thing is confusing to me can anyone make sense of my problems. I really want the fullscreen to function the same way just from the topright instead of bottomright.
the offsets don't work quite the same as the regular dims...
http://www.krpano.com/forum/wbb/inde…D=1473#post1473
Zitatthe ox/oy parameters are not related to the origin/align parameter like the x/y parameters,
they work always the same: -x = left, +x =right, -y = up, +y = down
sometimes it helps to draw out on a piece of paper what is being done...
Hi!
Got a multi hires panorama image, and it seems like the controls wont work at all. Just left/right.
Is it possible to get it to wotk with a "flat" panorama.
Have a look at http://www.stevenilsen.no/files/Harstad650/harstad.html
Thanks!
Steve
I can't see the controls at all, and your XML do not has the code to show it....
but GREAT pano :)
Try to control the picture with your mouse. If it can't be controlled up or down with the mouse, I don't think the camera controls can do any differently. I created my own flat pano and was unable to scroll up or down either, probably the whole theory behind the flat pano.
Jarredja
Is it possible for include a code to make the camera-controll buttons partially transparent (0-100%), while the user turn in the panorama?
Maybe in combination with mouse-rollover (makes the controls nontransparent)?
Thx, JAT
this would be easy - add in the xml:
<plugin name="camaracontrol"
alpha="0.2"
onover="tween(alpha,1);"
onout="tween(alpha,0.2);
1. rotate the triangle 90°CCW in Photoshop
2. Change oy to "-55"
3. Change align="righttop"
Phil
I download the source file of the plugin and I can not open the fla file.
Flah using is cs3 and error message is: unexpected file format
Thanks a lot for your help
Hello Andrei,
I like very much your plugin and i hope you will add other functions like fullscreen, stop and start rotation, sound on off...
Is it possible ?? thank you !
hi andrei,
i tried to open the fla and it didnt work for me neither. tried on diferent computers with cs3 installed. maybe the uploaded file is corrupt?
jan
Yes I also think its corrupt
I really like the camera style of buttons.
It works great, but I cannot get the full screen in the corner to show or work. I even copy/pasted the code you mentioned earlier....but do not find the http://fsbutton.png/plugin. ?
