this is the discussion thread for the Scrolling Thumbnails Plugin from Shanti Gilbert
Thanks Shanti
<thumboptions>
<thumbW>150</thumbW>
<thumbH>70</thumbH>
<InitialAlpha>0.2</InitialAlpha>
<font_type>Arial</font_type>
<font_size>20</font_size>
<font_alpha>1</font_alpha>
</thumboptions>
Are these all the available options? Or are there more coming?
Would like to see options such as animation speed/amount, offset amount, spacing amount, minimum number display, and width (pixels/percentage) added. But this is very awesome so far!*thumbup*
Ill see what I can do, maybe I will modify the source and add these, but, feel free to add them yourself (or anyone else for that matter) if you like, the source is included
Thank you. It is very good that you've included the source, but not everyone has Flash CS3 / CS4 and know how to program.
mmmm
i can't get it
i'm setting up a new tour and try to make the thumbnailscroller working...
Can somebody help me??
http://www.virtualtuur.com/Steam/tour.html
Thanx
Tuur,
do you have the console disabled... where you can use "o" to see if there are any errors?
The mouse changes to the handcursor when over in the left top area... like the plugin is there... just not showing.
He Graydon,
mmm i think i did... but how
(i had the wrong gallery1.xml..
started from scratch and..
Thanx
Yo people,
how can i change the place of the text that appears when i go mouse over thumbnail..
Thanx
Well here is an updated version of this plug in :)
totaln00ber, almost all of the options you asked for are there.
please read the readme.txt
ZitatAlles anzeigen18 MArch 2009
Added a few more options requested on the krpano forum, check the gallery1.xml for this options.
A brief explanation of all the options:
thumbW: Width of the Thumbnails
thumbH: Height of the Thumbnails
ThumbPadding: Space Between the thumbnails
ShownThumbs: how many thumbs are shown at the same time
ThumbOffset: Unfortunately you will have to change this depending on how many thumbs you are showing to center them, and its a hit / miss thing, will try to make this better. for 5 thumbnails its -100 so just try it until it works to your liking.
InitialAlpha: transparency of the thumbnails
font_type: For the descriptive text
font_size: For the descriptive text
font_alpha: For the descriptive text
font_color: For the descriptive textIf you feel like it I do accept paypal donations on shantic@gmail.com
Example XML
please add as many <pic> as thumbs needed.
where <about> is the text that is shown on top of the thumbnail
<panoToLoadXml> is the action to be called from your krpano XMLXML Alles anzeigen<?xml version="1.0" encoding="utf-8"?> <images> <thumboptions> <ScrollSpeed>25</ScrollSpeed> <thumbW>140</thumbW> <ThumbPadding>20</ThumbPadding> <ShownThumbs>5</ShownThumbs> <ThumbOffset>-100</ThumbOffset> <thumbH>70</thumbH> <InitialAlpha>.2</InitialAlpha> <font_type>Wide Latin</font_type> <font_size>15</font_size> <font_alpha>1</font_alpha> <font_color>0xffffff</font_color> </thumboptions> <pic> <thumb>../thumbs/nostalgia.jpg</thumb> <panoToLoadXml>s1</panoToLoadXml> <about><![CDATA[Text To Show]]></about> </pic> </images>
Tuur:
You will have to modify the .fla to move it, but try the new version i think it fixes that bug you have.
Klaus:
please update the plugin page :)
and here it is
http://rapidshare.com/files/21089723…3_18mar2009.zip
Shanti
btw, there is a known bug, the pane scrolls over the thumbs, so at one point it looks like they are gone. still trying to figure thie one out, will post an update as soon as i find a fix :)
Thanx Shanti.. very nice...
I Found the bug, and fixed it
http://www.vallartarestaurants.com/panoramas/krgm/m.php scroll to the end.
but I am not at home right now, so I will upload it tomorrow :)
Shanti
wauw that's a big project...
can you make the loading letters smaller and verdana or so ??
Thanx for your input... i have to learn more about flash..
Cheers
Ok here it is, new version with 2 bugs fixed
Zitat19 MArch 2009
Fixed: Scroll end bug, now it will stop at the end of the thumbnails
Fixed: Loaded text now respects the XML optionf for font
Tuur: check this new version
Link removed: (old version)
Regards
Shanti
I have now also updated the the userplugins site
https://krpano.com/plugins/userpl…sforkrpano/#top
Thanks Shanti!
He Shanti,
i have a view problems..
my thumbs scrolll out of screen til you see nothing
I can't change font type (doesn't work)
And the loading letters are still big...
Would you be so kind to check the first problem ? The others come later i think.
Maybe i make a stupid mistake..
http://www.virtualtuur.com/Vlietlanden/tour.html
<images>
<thumboptions>
<ScrollSpeed>15</ScrollSpeed>
<thumbW>120</thumbW>
<ThumbPadding>15</ThumbPadding>
<ShownThumbs>4</ShownThumbs>
<thumbH>60</thumbH>
<font_type>Geneva</font_type>
</thumboptions>
Thanx for all
Shanti...
i have the same problem ... trying for some hours now to change the font type ... always 'Wide Latin' is appearing ... whatever i do.... can't change it .... it seems to be fixed and you didn't give the fla ... so ... any advise for us ?
mthrills
Sorry about that bug :(
I fixed it
Tuur: did you use the new version? the scrolling to end was fixed.
The source *is* included on all my zip files
Attachment removed: Old Version
Regards
Shanti
