I have a question before i start playing with soundinterface...
i like that the music keeps playing when i go to another pano. is that no problem? or impossible or should i make an second xml..like MA did with the mask thing.??
Thanx
Thanx
No offense, but that's kind of stupid... why pay for you OWN music? you can't use your own music unless you pay?
maybe you should consider joining a different mafia :P
it's a bit different...
Don Tuur
this is possible, just make a playsound(...);
it will only stop when it's end (or if you set looping then not)
or when stopallsounds() or stopsound(..) was called
Hello,
Where I must put this playsound(..) command? and it is possible to do this song playing all the time, and not began from the beginning?
thanx!
