there is a new krpano tools update online - krpano tools 1.0.8 beta 9 (build 2009-12-30)
news:
all tools:
- experimental PSB reading supportbest regards,
Great!
Thanks!
news:
all tools:
Great!
Thanks!
whohohohoho... thank you Klaus...
I have some trouble in file encryption with 1.08 beta 9 2009-12-30 build
I use kprotect gui tool encrypted a external XML file and a Jpeg file at the difference time
The first: After I encrypted a external XML file, I open the 'protected' Krpano swf ,it can't show anything only a black window.
The second: I test encrypted a external Jpeg file,through the 'protected' Krpano swf I got a message " ERROR: decoding failed - panodata/pano1/preview.jpg"
I didn't know why happen these things
are you using a 'protected' swf build with the beta 9 kprotect tool?
Yes I'm using a 'protected' swf build with the beta 9 kprotect tool 2009-12-30 version ,the latest one
can you upload the files/example anywhere or send me the files,
then I can try to find out more, but normally it should work...
ha, it works now. I mixed the new version and the old one of the protect tool yesterday. thx
Hi Klaus!
This new kencrypt tool rocks, I really like it
I am running into 2 issues though -- none of them being a big deal, but a bit annoying (Tools 2009-12-30 release, reproduced on both OS-X Snow Leo 64 bits and Debian Lenny 32 bits)
First, the overwrite option 'ow' is not recognized:
$ ~/bin/krpanotools-1.0.8-beta9/kencrypt -ow $PWD/pano.xml
option: [ow]
kencrypt
ERROR: invalid or bad argument: -ow
Second, it seems to work only if you specify full path for the files:
# The following does not work
$ ~/bin/krpanotools-1.0.8-beta9/kencrypt pano.xml
kencrypt
ERROR: no input files
# While this one works
$ ~/bin/krpanotools-1.0.8-beta9/kencrypt $PWD/pano.xml
kencrypt
encrypt: [pano.xml] -> [pano.xmle]
... and cherry on the cake, it would be nice to be able to use it as a filter/pipe -- I mean being able to do something like e.g.:
This example as such is useless, but I am thinking of using kencrypt to encode xml generated dynamically (e.g. in php) and a pipe is much more easy and efficient than playing with temporary files...
right, I just forgot to implement it
check out the new version (2010-01-05), now it works,
would be possible of course, I will add such in one of the next versions,
Euh... what is the PSB ?
It's a Adobe image format, like PSD, but for (very) large images
right, it's the "Photoshop Large Document Format",
it supports images up to 300.000x300.000,
btw. normal PSD images are also supported,
Yep it works! (and I like the rename option as wel )
Hello,
please help.
If I download BETA9 of KRPanoTOOLS I get bad CRC in kprotect.exe during unpacking.
Can anyone send me the package?
THX
Marty
PS: I tried download with different IE browsers but I get the same CRC error in krprotect.exe.
Martyhr,
What version are you having issues with? Mac, windows, 64bit ???
Win32 but it is strange.
It happened only on my LenovoT61p notebook with XPSP3.
I downloaded on my old HP and extracted correctly.
Hmm,strange, but it works.
See http://www.virtualczech.cz/kraj-pardubick…dubice-otuzilci
marty
I'm curious. The krpano.swf in the krpano tools beta 9 package = 106.469 bytes
while the krpano.swf in the krpano beta 8 package = 100.834 bytes
Is this just compression or did you add some new stuff/fixed bugs? Which one is the best to use?
Hi Zephyr,
The beta 8 one is the last official release but the pre released beta 9 one from the latest tools package isthe one you could use .
There are already some beta 9 thinks there but not all..
Klaus told me that that one is the one to use now when u like to use beta 9 features allready like snowplugin , stage settings etc etc..
I hope this helps
Hi Zephyr,
There are already some beta 9 thinks there but not all..Klaus told me that that one is the one to use now when u like to use beta 9 features allready like snowplugin , stage settings etc etc..
I hope this helps
Thnx man
